I've been trying to create a scene that when motion is detected it checks the current light condition in the room and turns the light onto 10% if it is dark.
I'm using fibaro dimmers and aeon labs multi sensor
I can get it to sense motion and change the light to 10% but if the light is already on, then it dims the light down to 10%
I'd also like it to switch off after 10 seconds or so
please help ?
5 answers to this question
Can you post the code you've written so far so we can have a look through it?
I have done something similar, see my scene below.
Basically IF my night variable is enabled (I have another scene triggering this variable between Day and Night and using it for many other scenes behavior) , and IF the lamps are already off and IF there is movement THEN turn on the lamps AND then turn off after 180 seconds. I added the OFF command separate and not a timer (in the red fields) as in previous HC2 version it was suspected that timers consumed a lot of CPU so I'm avoiding them.
This might work for you:
Another go only movement, 2 lights ,Daypart is a variable DayTime or NightTime (set using sunrise/set)
Detects movement at night, if lights are off and if its before midnight sets lights to level 40 and waits 180 seconds, any further movement resets the clock, after 180s will dimm light gradually
After midnight dimm level is 1
Can you please adjust your code, so I can use fibaro motion detector to measure light level and only execute the scene if the light level is below a certain level( as in the example above this)..This is more accurate as sunset/sunrise variable
