Hey, can someone tell me how i can set up HC2 to switch an FIBARO Switch on/off when a FIBARO Door Sensor is used? When i make an association on Group1 of the Door Sensor to the Switch nothing happening. What is my Problem?
I never got the Fibaro door sensor to work with groups either. I ended up creating two scenes, one for opening the door (switch on) and one for closing (switch off). It works fine, even though it's probably sub-optimal.
Btw, I also have a PhilioTech 4in1 and that one clearly marks Group 2 as being the "light switching group". And it works too, even taking the brightness in the room into account (eg. when it's daytime it won't switch on the light).
I tried this and worked like a charm. Tried different settings (push button or normally closed/open) all worked!
I used dimmer module and added this to door/window sensor group 1. Waked up door/window sensor by pressing tamper 3times and this way sensor started to switch on/off my light.
Lauri
    Manny thanks. Pushing three times the TMP Button was the trick!!
