Setting up alarm configuration - need help
Hi all,
I am new to this and really like the idea of home automation. By now my house is equipped with door/window sensors, PIRs, switches and so on. About 40 devices (and becoming more
/emoticons/default_icon_wink.gif" alt=";-)" /> )
Unfortunately I found out that I am to stupid to configure the alarm. Meaning: I want my sirens to go of for 60 seconds if a sensor is breached. But I can only manage to activate the sirene. But it does not go off again.
Can anybody help.
Is there some tutorial for creating alarm scenes or scenes in general?
Best regards from germany.
Fritz
[ Added: 2014-01-28, 07:44 ]
Can nobody help?
13 answers to this question
Sounds like a must have feature for me to.
I'm also struggling with the alarm settings, especially the devices to turn on or off at alarm. It seems that notifications, pictures are working well, but no lights are going on during an alarm... If I want to edit the actor list, there are no device to turn on upon alarm... ??
    Unfortunately nobody seems to have an idea
    What is the problem I dont understand at the moment?
    Why dont you create a scenes like any other scene? If sensors are armed and someone breaches these, then start alarming and stop this after 60sec etc...
    That exactly is my problem: I don't know what command is needed to stop after 60 seconds
    What exactly do you want to achieve?
    Something like this?
    1) If house is armed and someone triggers alarm, then sirens will go on and start making sound.
    2) If alarm has been making sound 60seconds then shut it down automatically
    Yes, Lauri. Thats what I am looking for
    Then make a simple scene:
    If this or this or this sensor is breached and armed then turn ON sound and turn OFF sound after 60sec.
    I think there is some more advanced way to do this, but this should do the job what you are expecting.
    Edit:
    Try this:
    Fibaro alarm panel - activate panic scene and choose your siren to be device which will be turned on.
    Next: make a scene that turns OFF siren and add this to fibaro alarm panel and add delay 60sec.
    Hmmm…. my problem is that I don't know what EXACTLY
    /emoticons/default_icon_smile.gif" alt=":-)" /> I have to do to make a scene like this. I know what to do to activate the siren but not what command is necessary to turn it off again.
    Have you done any scenes using blocks?
    If yes, then make this scene:
    IF siren is ON then turn siren OFF and add 60sec to the red box (last one).
    Guest Lode
    Just change deviceID or using blocks like Lauri said.
    I don't understand what else you mean here ??
    Ah… thanks Lauri… I think thats it… sound good. I will try it.
    FritzB001
    try this;
    Sorry for my english
    Worked. Thanks a lot.
