help on connection of fibaro relay on standard 2 way light
Hello:
I would like to know if somebody already install the fibaro switch on a standard 2-way lighting circuit? I found in vesternet the information for the connection with a dimmer module but not for a relay module like the relay switch 3kW.
Below is the link of the connection for dimmer from vesternet
htatton
htatton,
You can connect it also in similar way, however please be sure that all buttons for O1 connect to S1 and all for O2 connect to S2. Please notice that you can only use pushbuttons buttons in such configuration.
    Thanks for the prompt reply and clarification.
    Htatton
