Beta version is designed for user testing and soon will be released as official.
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (available on the App Store).
3.581
- Optimized for remote access activities.
- Support for Fibaro Motion Sensor.
- Other minor bug fixes.
  • Answers 47
  • Created
  • Last Reply
Guest Lode
Andrew
Thx but they used to work before (3.580)
I didn't change anything.
Also manually triggered they work and no errors.
Lode, and what error you get? why they crashing?
i can bet that you not check is json is complete, script get empty json and crash
Lode, if you report problem with LUA always show us debug, we really are not wizard, till we dont saw it we can always only guess
Guest Lode
Andrew,
I said that when i run manually i do not see any errors in the debugger.
They just don't start at the given time.
I understand it's not easy for you to give an answer to this issue.
Tonight i will check everything once more.
Thx...
Lode, because not always you get empty json, add status, errorcode, pcall and show us a logs then we will tell you if bug is in your code or in ours
Guest Lode
Andrew,
Found it, i had a wrong deviceID in one of my scenes. (after re-including)
But is it normal that the other scenes also don't start when you have only one scene that can't start ?
no, every scene is separate, if one crash other will work
Guest Lode
Hmm.......very strange, everything works normal now..
Thx anyway.
