Heating Problems. Average House Temp.
I've juts moved over to a HC2 from Veralite. I've got everything working well apart form one thing:
I'm really struggling to get my heating working as I did in Vera.
This is my situation:
- I have a boiler with a Z-Wave Secure Boiler Receiver HRT on it.
- I have a Horstmann HRT4-ZW Thermostat
- I have 2 x Aeon Labs multi sensor, which I use to give room Temperature.
On my Vera set-up I had a "Virtual Thermostat" which basically got the temperature values from both Aoen multi sensors, and also got the temperature from the Horstmann Thermostat. It then took an average of the three used that to decide if it should turn the boiler on or off, depending on the setpoint (The set-point was set through iPhones). it then controlled the Boiler Receiver (just a basic relay)
It meant the Horstmann was basically just working as a temperature sensor but other than it it worked perfectly.
I've been able to set-up the Horstmann Thermostat, Receiver and Temp sensors on the HC2 but I haven't been able to get all three working as one. My thermostat controls the boiler switch, but the other two temp sensors are now not included in the temperature read-out. It's working as a normal heating system but I would really like the temperature read outs from the Aeon's to be included so basically there was an average house temperature reading to control the boiler against. I also need to be able to set the set point from iPhones.
Is this possible? I've tried to link devices but it doesn't work.
Any help would be greatly appreciated.
Thanks!
tom
