Has anybody managed to set virtual device name through HTTP
Has anyone managed to set a virtual device name, IP and port using HTTP api. without replacing the complete device JSON?
Thanks for any hints if you have managed.
6 answers to this question
I think you can't do that with the API
    Thanks,
    I know I used to be able to replace the complete json but it is not sensible as a regular process.
    I will have to see if the next release gives a way to configure devices for set-up reasons.
    Would also be nice to be able to create variables through the api. Ever grrowing wish list
    It seems you can't even PUT the full JSON object back. It always fails with the response:
    {"type":"ERROR","reason":"WRONG_TYPE","message":"properties[value]: expected string"}
    The API can't handle nested JSON objects. data before the properties can still be changed
    Reported on bugzilla.
    Have anyone tried converting the json into a single string instead of a multidimensional array?
    Just copy the entire json out, search-and-replace the name you want to change, and then fire the entire package back at the fibaro as a single string using post? I'm thinking maybe HC2 doesn't know how to parse an entire string using PUT (I guess PUT is the wrong method if you want to replace the entire thing anyway).
    I know it is a bit clunky to do it that way, but that should work if you have the right permissions.
    Rob, what response do you get to your put request? If it doesn't change the json, it must give some sort of error response.
    Well PUT actually was accepted after a HCL restart today. Virtual device ip is not updateable though. name & roomID I can change but not any properties.
    You can set the complete JSON or used to be able to
    as a starter but that is just mad and probably a bit dangerous on a regular basis.
    Notice all the LUA is in the JSON so think what HC2 has to do if you write the complete string. OK for setup but not something I would do on as a production piece of code. My issue was that I wanted a remote system to name the virtual device and this would be on each connection by the remote system if the name was not correct.
