Hi all,
I want to install a dimmer with a double connector switch. One part of the switch is for increasing and the other for decreasing light. I see in the manual that it's easy, only 3 wires and done. No I want to do it with two double connectors... Do you know how to do it? I think one solution would be to connect in serial both of them, so all the wires from the connectors will go to px p1 and p2 directly
Thanks!
Hi all,
Thanks!
Serial will not work. You will have to be able to wire them in paralell. But, what you actually describe in your text is paralell, so it should work nicely.
    Yes!! Its paralel... You are right
    Thank you very much!!
