Lockzi 1
I would like to through LUA check for activity before setting my "home" variable to 0 (i.e. no one home).
I am checking for the household members iphones, but maybe if the cleaner or someone else is home the whole apartment should not go dark as soon as the system considers no one to be home. My way of reasoning is that if no iphones are home, it should check for last activity. Door sensor, light switch. You can easily see the activity through
although it lists temperature changes etc. Is there a way to do this through LUA?Thanks,
Lockzi
Update: Is this problem unsolvable or not to defined? 60+ views and 0 replies. If you need more information on what I am trying to accomplish let me know please.
