Lockzi 1
I got tired of having to add devices to a block scene to turn off...
Therefore I am trying to loop through all devices with LUA and send them turnOff.
The loop works fine, I get all ID: s, but the command "turnOff" is not working as they are still lit.
Debug output:
Any help to why "fibaro:call(i, "turnOff");" does not work is appreciated!
Lockzi
[ Added: 2014-02-02, 17:24 ]
So, it actually worked. But only for dimmers. Relays are not even identified even though they have the Controlled Device: Lightning under advanced settings.
The reason is that for relays the ControlledTypeID is 2, and not 23 (as for dimmers...)
[ Added: 2014-02-02, 17:33 ]
Allright,
so final code that's working!
You could easily reverse it by changing turnOff to turnOn.
7 answers to this question
