Scene information
Hello everyone I need your help:
in this scene i need: if 15 minutes before sunrise and / or 15 min after sunset
I open the door of entry
and the light of the table is strictly off
then turn on the LED lights that will turn off after 30 seconds
I need to understand why there something wrong in the table lamp
regards ...
You have to work with a predefined variable for this.
1: Make a predefined variable named 'leds' (or any name you want)
2: give it 2 values (on, off)
3: make a scene to activate the variable, see
(example of my own variable)
4: make a scene to deactivate the variable, see
5: make sure the 'Start when Home Center 2 starts' is checked
Now you have to delete the 2 timelines in your scene as shown above and replace it for the variable. If variable LEDS = ON then.... the rest of your scene.
