FGS-221 Double click turn on associated devices
I do have an FGS-221, and i am trying to turn on the associated devices after double clicking only.
I found parameter 6 and 7
they are: Sending association command for wall switch key no.2. Default setting: association command is sent when key 2 is ON or OFF
The question. the settings are:
Device OFF sends commands to associated devices. Double click turns associated devices ON; associated Dimmers are set to level memorized at turn OFF.
Device OFF sends commands to associated devices. Double click turns associated devices ON; associated Dimmers are set to 100%.
Both does nothing on the associated device. but if I choose: Device ON / OFF sends commands to associated devices
They turn on/off together with the device.....
Am I doing something wrong?
