Tcheri 15
I've multiple Secure thermostat and want to control one switch to start/stop the heating.
So I want to have the switch set to ON if any of the thermostat is on demand and swicth OFF when all thermostat are not in demand anymore.
The problem is that if I use the group 2 association, for the ON, no problem, but the switch goes OFF if any of the thermostat is not in demand anymore.
-> do I miss something there ? Can I have a solution using group association ?
Other solution is to script in LUA : I can get the value and valuesensor (defined temperature and measured temparature), but I can not know if the themostat is on demand or not. This is very usefull because I want to use the hysteresis mechanism of the secure thermostat. So comparing the two values are not enough for me.
-> do I miss something ? Can I know if the thermostat is on demand or no ?
Thierry
