stevenvd 51
Simple scene to detect motion direction detection. First detecting motion and then door opening to turn on a light.
Can ofcourse also be turned the other way...
Works like a charm in combination with the Auto lights of Virtual device.
Any suggetions to make it even better? For instance for when the second motion or door sensor is already triggered? Or maybe for when you have 3 detectors, or two different rooms to go into?
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Got a nice alternative:
In the last one, it actually turns the light on with the first motion detection.
When the second is also detected it will leave the light on. When no motion is detected it will turn the light off. This means that you can use it for a hall way. It will turn the lights on in 3 rooms, the room you go into will stay on, the other rooms will turn off.
Have to build in a check if the light wasn't already on... other wise when someone else is in the room, the light will be turned off
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />0 answers to this question
