hugohekk 0
Hello all,
What is the best way to switch a scene (on and off) in combination with a normal wallswitch? I saw that a Door/window sensor can do the trick but they are to large to put behind a normal wallswitch. I don't want to put an extra wire into the system so i prefer a battery powered device.
All my lamps in the house are equipped with the Fibaro FGD-211 modules. The are build into the lamp itself.
I hope to hear from you
Regards, Hugo
17 answers to this question
