How to enter sirees into alarm panel?
I have an everspring sirens and want to add it as an action into the alarm panel.
Meaning I want the sirene to make noise if a sensor it breached.
I managed to do it with a scene but here only with one sensor breached. If I add other sensors it does not work anymore.
Can someone help and explain to me how I can arm all sensors via the alarm panel and make the sirene sound if one of them is breached?
Best from germany
Fritz
[ Added: 2014-02-17, 07:22 ]
SORRY WRONG FORUM
12 answers to this question
Guest dsilletti
Hi, use LUA, this is a scratch from my code:
35,39,43,54 and 56 are device ID of the sensors,
60 is the ID of the siren,
65 is my iphone for push notifications and 2 is my account for the email notifications
only if the sensors are armed and breached the siren and the notifications will start
That´s helpful - thanks.
Just one stupid question: Where do I find the ID for my Iphone or push notification?
[ Added: 2014-05-22, 15:51 ]
Sorry, I ment the ID for my Iphone and for emails....
Guest dsilletti
login to your HC2, then with the browser go to this web page:
http:///api/devices
you will see all devices in json format.
Search for iPhone (or the name that you gave to your iPhone), and you'll find the id.
Then search for your email address and look for your user id.
Then use these IDs in your scene.
Ciao
Domenico
Thanks - that´s great
dsilletti,
Does this also work in turning the sirens off when the alarm is being deactivated through the alarm panel? If not, what would you recommend?
Thanks!
Thijs
I have no experiences with LUA. Is it difficult to add something in the above scene,
- to make a delay of 30 seconds, before my devices are getting armed (so that I have a chance to leave the floor after activating the scene) and
- a delay of 30 seconds after recognizing any motion before triggering alarm (so that you have a chance to deactivate it) and at least
- to switch a micro switch on when the alarm is activated (so that everyone can see, that the alarm is activated right after entering the floor)?
It would be very kind, if someone can help me with this codes please.....
Guest dsilletti
dsilletti,
Thanks!
Thijs
I manually switch off the siren from iPhone/web gui, I will see if a better way is possible.
Domenico
[ Added: 2014-06-04, 12:57 ]
in HC2, if you go in sensor setting you can find a section Delay Arm / Disarm where you can set Arming Delay (I setted this to 30 sec).
I configured this delay for all sensors, so when I activate alarm I can see in fibaro Gui/iPhone/iPad App the sensor with countdown before alarm is fully activated, for the alarm status actually I don't know how to check by LUA the alarm status, I will give you updates
Domenico
Thanks a lot for this tip so far. One big problem is solved (without using a LUA code - so it´s save for me too
/emoticons/default_icon_biggrin.gif" alt=":-D" /> ). Great.
Guest dsilletti
/emoticons/default_icon_biggrin.gif" alt=":-D" /> Anyway you don't need anymore LUA to activate your siren, for the last versions with new Fibaro Alarm, just create a scene in blocks that switch on the siren, then add the scene in Fibaro Alarm panel, and set to run the scene after x seconds after alarm is triggered.
is a basic configuration but if you need only to activate siren is ok.
With LUA in the same time in one simple LUA scene I have custom push notify, custo email and custom SMS for each sensor and each room (SMS via Clickatell API), and other custom setting
Domenico
Yes, you are right, but I really like to have the more detailed information from your LUA script with the exact position of the motion detected etc. (it´s allways the problem between wishes and own abilities
/emoticons/default_icon_sad.gif" alt=":-(" /> - and it seems to be only a short step away)
[ Added: 2014-06-06, 13:11 ]
To include the delay within the LUA script might have the advantage, that it works just by starting the scene, even if the alarm panel is not available (like in the current version for Android Tablets).
I found this command fibaro:sleep(30*1000) but I still don´t know where I have to write it into the above LUA code to have a delay of 30 seconds for my siren to start after the alarm is activated
Can anyone help me with this problem?
Guest dsilletti
just before
where 60 is the siren
Regards
Domenico
ciao Domenico gentilmente mi daresti una mano per configurare i sensori con lavvio della sirena ho provato come scritto sopra ma non riesco
saluti
hello Domenico kindly would you give me a hand to set up the sensors with lavvio mermaid I tried as written above but I can not
greetings
