Accessing Insteon Device Status
mclass
I have continued with some success to control and integrate Insteon devices via an Insteon Hub (a PLM hidden behind an HTTP interface) as HC2 Virtual Devices
However, I am now at the stage of attempting to determine the status of devices (including their lower cost, battery operated wall switches).
This is proving to be beyond my (very limited) Lua abilities, and I am seeking some guidance (or even a full blown solution!) from members with the necessary knowledge.
To obtain the status of Insteon devices, it is necessary to:
- Send a "status" command to the device (I got to here, OK)
- The device then loads the status message into its buffer, and it is necessary to then send a buffer request (I can do this!)
- The buffer request returns an XML response that looks a bit like this:
02620EA7220F117F0602500EA72216A9442B117F (I can receive this in a browser, OK)
- The "level" of the device is returned in this response on a scale of 0 to 255 in the last two (hex) characters prior to the end wrapper (in this example "7F")
My dilemma now is how to:
(a) Load the XML response into Lua, and then
(b) Parse the response to determine the value of the status part, and then
© Adjust a virtual device slider to represent the level returned by the device
I would like to simply check the length of the message to make sure it's not a garbage response, and then look at the last two characters to get the level.
Any assistance/guidance references, would be greatly appreciated!
Mclass
