Integrating the new DanaLock from PolyLock.
Guest vipernor
Is there a possibility for ever having integration with EU doorlocks, like for instance the new smart DanaLock from PolyLock? Door Lock - BTZE100 (Circle)
12 answers to this question
In 4.x
+1, please for DanaLock.
Any news about? I have the device and I cannot use it with HC2. Please...
It's working with 4.x
Guest vipernor
    Define working for me please. Open Close and use of the standard pin code?
    Guest sebco
    Hi guys,
    It wasn't easy, I can tell, but I managed to include my Danalock with HC2 4.056. The communication between Fibaro and the lock is very laggy and it seems that HC2 is sending commands to the lock, but without success. So I can't lock/unlock from HC2, nor run a scene to move that bloody lock. I've read this the other day, on Vesternet: Security commands for locks not currently supported in HC.
    Anyone else is experiencing this? Fibaro, ca you do something to help?
    UPDATE
    Figured it out. It took me a while, 'cause, of course, no one from Danalock is telling you that you have to add the lock in security mode.
    Now it's working, I can lock/unlock from the GUI.
    If anyone else is interested in how to do it, just follow this steps:
    1. Remove the lock from HC2 if it's present by touching the User button on the lock until it's in inclusion mode ( 2 beeps )
    2. Re-add the lock. Touch the user button on the lock until you hear 2 beeps.
    3. Check the button Add in security mode if device supports it on HC2
    4. Click the Add button
    At this stage, HC2 should discover the lock quite quickly. Then you'll hear a series of beeps - HC2 is setting the locks parameters.
    Everything should work fine now.
    Hi guys
    just got my Fibaro Home Center LIte and I am having big problems adding the DanaLock. Tried all the trick here and still no luck. Factory reset, reset, removed batteires, etc, but no response at all when trying to add the lock to the HCL. Also upgraded to the latest beta in an attempt to get things to work, but no luck. Any other users who have had same problems and the solutions above have not worked, but other solutions have?
    Thanks that helped, now everything works!!!
    Hi guys,
    UPDATE
    Guest vipernor
    Okey, so Danalock is working pretty good with Fibaro..good.
    /emoticons/default_icon_smile.gif" alt=":-)" /> Very good!
    Now..If you by any chance got a previous model from polylock, your do not get the parameters. This basically means that it's not possible to adjust the time the engine runs in each direction etc. Not so good.. is it possible to download these parameter settings from the danalock somewhere? I mean it's worth a shot, since I can't use the lock as is.
