I have four Fibaro smoke sensors, the work fine.
Gives also temp. But I miss the baterijstatus in de right corner.....
Does it not have or..........
I have three of them and all of them are missing the battery indicator so it seems that this has not been implemented either in the interface (likely) or in the detector (unlikely).
The battery status exists, but I guess the indicator is missing for some reason. Should be pretty easy to set up a virtual device to show the battery status and send you a push notification, sms or email if the batteries are drained. But i think that the battery life of these things will be measureable in years! I've had mine installed for over a month and have logging on them. None of my four detectors have dropped from 100% yet!
    if i wake it up i can see the indicator also if i reconfigure device.
    then it tels me "Device is a sleep"
    Dalle1985, to make for eas device also a virtual device is pretty muts to do,
    but it will work!
