What to use to know Voltage of Batteries from Solar System
Hi!
I've got a Solar System at home that works at 24V... So I need a sensor that can read from 20V to 30V. What can I use? A universal sensor? And how to do that?
Best Regards,
Joao
Hi, a voltage divider network in front of an RGBW-controller will be able to do that by using it as input and dividing the maximum read voltage by a factor of (at least) 3 and then setting appropriate start and stop values for the input translation. In this case I would divide by say 4 for easy numbers by using say one 1 kOhm resistor and one 3 kOhm (or 3.3 kOhm if a 3 kOhm is hard to get) and then set the lower limit as start 0/display 0 and the upper limit as end 10/display 40 with unit V for a sensor of type "Other". You can calibrate the values once the divider network is in place and it works by measuring the actual values and adjusting accordingly.
    Thank you for the reply... Can you please make me a diagram with that you are explaining.
    Thank you very much!
    Something like this (the temperature, humidity and light sensors obviously don't have anything to do with your stuff. They were in the picture I borrowed from the RGBW manual):
    Thank you!
    Now I'm waiting for the RGBW Module. When it will arrive I will test and send feedback to you!
    Cheers
