FGRM222 EU - not the same info and parameters on two units
Hi everyone, I installed about 1.5 month a FGRM222 EU. Today I installed two new FGRM222 EU.
All of them run version 22.22
The curious thing is when I access the advanced pane in the device panel, I don't have access to the same parameters.
The interface of the "old" one has a bunch of rows with parameters numbers, and drop down menus to select values.
The interface of the new one has clear and readable info about each parameters. you can select option with tick boxes.
The only difference between the first unit and the two other units, is that the first unit was installed with the previous HC2 software. I'm now running 3.580.
Is there a reason why such a difference ? Do I need to exclude the device and include it again with 3.580 ?
Looking forward to reading you guys !!
P.S thumb up to the fibaro team for parameter 32, such an helpful feature for me !!! great job ! I probably discovered it because of that new interface I couldn't see with the previous unit.
press reload parameters, or reconfigur the old device. If it doesn't work try to exclude and include the first one again. It should show up as the newer ones
    When you say reconfigure, do you mean delete the device Steven , and then make a new discovery ?
    thanks for your help.
    I reconfigured the device, and restarted HC2, but still no success.
    I'll open the wall switch on tomorrow, and will exclude/include the device again.
    Is it current to have to do this kind of things between two HC2 release ? I'm new to Fibaro system.
    be sure that in old device you got checked "use parameter templete"
    Ahhhok, it works now. Now I understand the purpose of these feature ! Many thanks A.Socha
    Solved !
    P.S I really appreciate this support at such a late moment !
