WiYantra 2
Hi all,
We have installed Aeon labs Minimote onto HC2, as a battery operated device reconfigured the device in advanced settings tab.
We tried with pre-programmed settings i.e., ALL ON & ALL OFF functions worked fine, the Minimote is able to communicate with HC2.
Written the LUA code on HC2 to configure the Minimote buttons, after saving all the settings tried to operate the Minimote, no triggering has happened. The LUA code tried is as shown:
HC2 version is 3.580
Minimote ID is 43
Light to be turn ON ID is 10
%% properties
43 sceneActivation
%% globals
local ButtonPressed = fibaro:getValue(43, "sceneActivation")
if ( tonumber(ButtonPressed) == 1) then
fibaro:debug("Minimote Button 1 Pressed")
elseif ( tonumber(ButtonPressed) == 2) then
fibaro:debug("Minimote Button 2 Pressed")
elseif ( tonumber(ButtonPressed) == 3) then
fibaro:call(10, "turnOn")
fibaro:debug("Minimote Button 3 Pressed Tube light M2 ON")
elseif ( tonumber(ButtonPressed) == 4) then
fibaro:call(10, "turnOff")
fibaro:debug("Minimote Button 4 Pressed Tube light M2 OFF")
elseif ( tonumber(ButtonPressed) == 5) then
fibaro:debug("Minimote Button 5 Pressed")
elseif ( tonumber(ButtonPressed) == 6) then
fibaro:debug("Minimote Button 6 Pressed")
elseif ( tonumber(ButtonPressed) == 7) then
fibaro:debug("Minimote Button 7 Pressed")
elseif ( tonumber(ButtonPressed) == 8) then
fibaro:debug("Minimote Button 8 Pressed")
else
fibaro:debug("No response")
We have taken reference on writing the LUA code from below link
Please help us how to solve this issue
10 answers to this question
