I've purchased 4 Philips Master LED PAR20 at 6.5W, so they should be able to run without a bypass, but actually they flicker nevertheless.
Then I tried to replace one of them with a 42W bulb, and the flickering on the remaining LEDs went away.
The question is: Should I add more bypass modules, until it works? Has anyone experienced anything similar?
Guest spazpeker
I have had to add dimmer bypass to circuits with 10x 6w Megaman bulbs to stop flickering
I have no hands-on experience with LED's in combination with the fibaro dimmers, but there are some parameters that can be changed that influence flickering problems too. You'll have to search the forum a bit to find some info on that.
Also I think you shouldn't mix different types of lights on one dimmer since either the lights or the dimmer could be damaged.
    I've tried different steering values, and found that 140 gives the best result, but flicker occurs when dimming anyway - even though the total load is 26W and a bypass is installed.
    I was just wondering if anyone had experienced needing more than one bypass.
    Flickering is always going to be an issue because of the way the triac dimmer interacts with an LED bulb. Also, using a bypass completely defeats the purpose of an LED lamp as I'm guessing it is just a resistor which will mimick an incandecent bulb. It will remove the flickering, but the consumption will be similar to that of a normal bulb.
    I considered using a fibaro dimmer too to control some LED lamps, but chose to cough up the extra dough for Hue bulbs instead.
    I have created a virtual device which integrates easily and provides simple yet powerful scene integration. This works flawlessly.
