Dino 0
I am trying to connect a Merten /Schneider Wind Sensor with a 0-10v output to a RGBW module. I already have a Co2 device with a Analoge out connected to the RGBW unit and that works fine. (one wire 0-10v output).
The windsensor has two wires which are described as the output. One output is described as + and one as a -.
When I connect the + (green wire) to the RGBW module it gives a value once and sometimes with hard wind it switches between two values. But further no updates on wind speed. When I put a voltmeter between the green and yellow it shows the voltage and it changes probably due to the wind.
The RGBW has just a one wire input for analoge input. Anybody any idea how to connect it to the RGBW module.....Thanks in advance
3 (green) - Output 0–10 V DC = 0.7–40 m/s (+)
4 (yellow) Output 0–10 V DC = 0.7–40 m/s (-)
English guide
French/German/Dutch guide
