How do i configure the RGBW controller for a on/off switch?
I just installed and included a RGBW controller. It's copnnected to four relays coming from my home alarm. I want it to react when the the four different relays connected to my alarm turns on/off.
I see it in my HC2 and have configured it as an input and other. But i don't seem to get it to react through a scene when i choose turn on?!
What do you have connected to the R, G, B and W outputs on the module?
I'm assuming you have the relays individually grounding IN1-4 and the relays are only causing a momentary contact across those terminals? Or are the relays latching?
    Nothing right now, maybe that's wrong
    /emoticons/default_icon_neutral.gif" alt=":-|" /> I just want the RGBW to report to my HC2 which combination of inputs are ON so i can do a scene that for example turns off all the lights when i arm my alarm (Siemens SPC4320). The SPC can be programmed to turn these for outputs on for a special event like someone disarming or a alarm being triggered. When this happens the desired output switches a relay.
    So i want to create different scenes depending on what combination of relays are on. Is that possible?
    [ Added: 2014-03-02, 17:50 ]
    I got it working!
    It was no problems at all, i had connected the realys from the alarm the wrong way
    /emoticons/default_icon_redface.gif" alt=":oops:" />
