jcilissen 2
Hi
I am going to install 8 Airco's from Samsung wich are controlled via wifi
There is an Apps on Andoid to control it from a distance ( Samsung CAC )
I wonder if it is possible to integrate this in the HC2
There are panels for humidity , Airco and heating but they do only on/off of an actor and this is not enough
Some scripts are needed to sent to the airco's
For the Samsung commando's are needed to send to the Airco ( probably an IP address ) , like turn temp higher or lower , or activate dehumidity mode , put in sleep mode etc ...
Might this be possible / feasible or am i expecting/dreaming too much
/emoticons/default_icon_biggrin.gif" alt=":-D" />Please login or register to see this image.
/emoticons/default_icon_biggrin.gif" alt=":-D" />Thanks for the answer
Jos
