1. How to accomlice a local HTTP request like
in a scene? How to write it?
2. How can i follow what happens in my home (From dashboard/IOS App). Like an event log? When did the Door opened, when did the Freezer stop from working.
3. How to create a Virtual sensor and trigger it eg from my Iphone using an external URL?
possible?
4. Scene blocks like ELSE and RANDOM will that come? IF lights is ON then this ELSE this. RANDOM id like to simulate precense at home to every hour generate a number and depending on result use that to turn ON/OFF light.
5. Scene Events from FGD-211 (eg. double and tripple click) are avalible?
6. I'd like to create a scene that -1h to sunset turn on the light. How?
7. Will there be any sonos/samsung tv plugin comming in 4.0?
So you bought a HC2
    No a HC2 AND a HCL
    - Create this request in a virtual device button and call it in your scene
    set your virtual device with IP 10.0.1.10 and port 8080 and put this code in a button
    Not tested but i think it work...
