[VD-LUA] Change text of button by variable?
Is it possible to change a buttontext depending on a variable status?
For example, If a global variable=1 then a virtualdevice button shows the text 'ON' or when a globalvariable = 0 the buttontext is "OFF'
Thanks.
4 answers to this question
Lambik, no you can't do that. there a solution though: edit the json of your virtual device and re-inject with PUT method but the label is refreshed only after page reload...
    Do you have an example?
    I use this code to change the label for a button you can adapt the code for your needs:
    /emoticons/default_icon_eek.gif" alt=":shock:" /> WOW!
    When ever you have the time, can you please explain this code step by step?
