Need a Advanced Ping Script
Can a LUA script be made so I start a ping from my HC2 and it show in someway the Ping time and time out in a window? Can this be dun and can somebody make me a LUA script on it,
I wanto haw ping and I can set how many ping and if fails it try's agen after xxx time and if it can ping it shows the Ping time and how many packets it haw lost and sent
4 answers to this question
it's not a true ping, you can't monitor timeout but you can check my code here:
Work great for me to ping equipment, only one requirement: you must have a port open on target device
    I haw now setup ur script whit correct ip and port, but where can I find info if it get any connection?
    fibaro:log output information just under your virual device on homepage, or you can replace fibaro:log with fibaro:debug... (Fibaro:debug print info in debug window).
    Tanks fore the help
