Switch scene when state of wallswitch is changed
With some help from this forum i created the following scene for my TKB wallswitch:
This works ok, but there is a downside. When i activate the scene with my iPad, for example scene 3 (lights on), i have to switch the wallswitch 2 times to activate scene 4 (lights off).
Is it possible to switch the scenes if the state of the wallswitch changes instead of the value?
4 answers to this question
Can you paste scene 3.
With adding an OR statement to the IF we should fix it, but then we have to know the lights you enable in scene 3.
    Hi Remko, thanks for your quick reply.
    Here is my scene 3 (livingroom on)
    I don't know why the scene is inportant by the way
    /emoticons/default_icon_confused.gif" alt=":-?" /> .
    To make it a little bit more clear:
    When the wallswitch changes the state (0 to 1 or 1 to 0) the correct scene has to be pressed. There is one scene that says: livingroom on, the second scene is livingroom off.
    There is some part of the code that has to check if the scene is active or not i think.
    pfff, one day is can write lua code i hope
    You can do it in 2 ways:
    1:
    If you change the if statement to:
    if (lightlevel == 1 and tonumber(fibaro:getValue(21, "value")) == 0) then
    It now also checks if device 21 is off and if so it "thinks"woonkamer is off so runs scene 3, otherwise scene 3
    I don't know if 21 is only used in the 3 scenes, but it should be.
    2:
    You can add a globalvariable (panels/variable panel) "woonkamer".
    You then have to add fibaro:setGlobal("woonkamer", "1") to scene 3 (after you enable the lights) and setGlobal("woonkamer", "0") to scene 4.
    In the wallswitch scene you then have to change the if statement to:
    if (lightlevel == 1 and fibaro:getGlobal("woonkamer") == "0") then
    New scene 3:
    New wallswitch scene:
    You need to change scene 4 and add woonkamer in the variables panel!
    Solution 2 is a cleaner solution in my opinion.
    Succes!
    Thanks for the complete tutorial Remko, it works great. It is even woman-proof now
