mvrekum 2
Hello, since I am not a programmer I have a question for the programmers on this forum. In the introduction video from Fibaro there is a scene where the travel time between 2 locations (i.e. where ever you are and home) is calculated. I know it is possible using google maps to calculate the travel time between 2 coordinates. See this example which calculates the travel time between two city centers by car:
See
for explanation of the parametersIs there someone who is willing to write a script that pulls the location of a user from his phone and calculates the travel time to Home and store this in a variable to be used in other scripts as timer? Maybe it is even possible to recalculate the traveltime every 15 minutes if the original traveltime is more than 15 minutes, since the traveltime will change depending on how fast you drive
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> and the trafic situation.The goal is to start scenes when you are close to home, i.e. start the coffeemaker when you are 5 minutes from home.
6 answers to this question
