Hi guys,
Have any of you experienced any feedback issues with Fibaro plugs connected to audio equipment? I have a B&W zeppelin Air connected to a fibaro plug and from time to time, after turning on the plug, it will result in heavy feedback to the speaker (loud white noise behind the sound). Turn off the plug and on again, and it will be gone. There is no doubt that it is the plug as I have never had this issue before, and if I disconnect the plug and plug the speaker straight into the wall, there is nothing.
I have a SONOS "connect" and two active speakers connected to a wallplug. I use it on a daily basis since november and have not had any issues with it.
    Okay... I think I'll try switching around some plugs and see if it helps... I also have a B&W A5 and that has had no issues at all. So it might just be the one plug.
    Anyway, thank you for your reply!
