On the HC2 I'm using lua to control the individual outputs of the RGBW
How an this be done with the HCL
something like this
fibaro:call(318, "setR", "255")
by using http command
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
arg1 = red color
arg2 = green color
arg3 = blue color
arg4 = wite color for rgbw
    nothing happening.. this must be the correct code for my device
    turn on white
    you got rgb or rgbw?
    try first
    if not work add login and password
    both are not working. using rgbw
    rgb connected to a led strip
    W connected to led spot. With HC2 working fine.
    hope there will be a good solution for the rgbw control.
    Also the following doesn't work for me:
    while this does work when I enter it in the browser...
    @steven thanks for the test.
    individual control of the rgbw is a must from scenes.
    please add the rgbw slave devices to the template.
    I understand, I was just checking if a simpler code set on an ON OFF device would work in the Virtual device, but even that doesn't. So maybe a bug in the Virtual device or we do something wrong?
    Any news?
    Found out that the http connections are very unstable.
    sometimes they just don't work..after a restart it's working again..
    but still no succes with RGB
    Http commands from hc2 are also very unstabel. Indeed after reboot they work again.
