Another solution to create graph/see history of any device
Instead of installing additional server localy, there is a possibility to use cloud plateforms to log any type of value and represent them on graphs.
I've try 2 plateforms :
and
It's working quite well, from virtual devices.
It's the same principle for the 2 : create your account and than create one or multiple feed/channel there.
Those solutions are not perfect (especially to navigate in past data), but they are free and simple and solve a lack in the fibaro plateform (it's a paid option on Zipabox).
Sample code for ThingSpeak (I use a slider in LUA to define the time between 2 post.
For OpenSense :
7 answers to this question
Thanks, works like a charm.
Only OpenSense is only available on invitation!
Guest Axel
Great. Works !
How to integrate the Graph in Fibaro ?
Is it possible ?
    No, I don't think so.
    In the mean time, I've move to Emoncms.org, it's much more powerful
    Guest Axel
    do you have an script example for using Emoncms ?
    Emoncms is a bit more complex : you have to create first inputs (the interface to HC2) and after transform inputs into feeds (on the plateform). You can find doc on the site.
    Here is an example of code :
    [ Added: 2014-08-20, 15:48 ]
    And example for input definition on Emoncms
    Guest Axel
    Thank you very much.
    I managed it for my HC2.
    A little bit more complicated to configure/understand than ThingSpeak but much better.
    Do you managed it to put a link to the grap on a button of the virtual module ?
    i'm doing somthing ronge: get
    [DEBUG] 18:57:07: line 9: attempt to index global 'Net' (a nil value)
