Simple xml readout
Hi all, i basicly want some value's from an xml output into a virtual device. I've seen some examples here and there but most seem to be either to big or complex or it tells you to convert xml to json via another webserver (which i dont want)
In the end i get this back from the device:
Which in xml terms is:
The keyname can be different and/or have more lines like that. So i will only grab the lines i do have and say if "Toestelstatus" = "Klaar" then set other values to empty.
Does anybody have a simple example on how to get those things without getting to fancy?
Thanks,
Erik
I don't think there is a simple way to do this directly on the hc2. To be honest, I do think the easiest way - even though you don't want to, would be to set up a webserver and convert to json using a premade script.
If you don't have a webserver, I am going to create a how to for setting up a low power (2-4 W) webserver for less than 50€ using a raspberry pi for my home automation interface. It is very simple to set up (it takes less than half an hour and will double as a NAS if you want) and can do almost everything for you that you could possibly need to interact with the HC2.
Alternatively, you could try your hand at building an XML-parser in Lua. But all that is going to do for you is create the same array as the json file will provide you ready made. There are some good examples out there, but personally (as I'm already running a webserver) I would go for the simpler xml->json->hc2 way.
    My preference is without a webserver, since i would think it would be possible. But anyways, i do have one on my qnap. If i convert it to a php i get this back:
    {"information":{"key":[{"@attributes":{"name":"Toestel","value":"Wasautomaat"}},{"@attributes":{"name":"Toestelstatus","value":"Klaar"}}]},"actions":{}}
    How would i go about getting that into a virtual? Since the json is a bit weird (attributes inside a key which is inside information?)
    riemers, you can parse your response with LUA, you should use match:
    Example:
    it should work.
    Ah yes, something like that is more easier in my eyes.
    Although some values might change and i can have some more key names, its always that same amount, so it doesn't need clever logic (as far as i can tell)
    Name "toestel" using json in lua:
    Information.key[1][email protected]
    For the toestelstatus you replace 1 with 2.
    The smart thing with using this, is that it is an array so you can retrieve all data without needing to know i.e. The name. It's much easier to integrate than having to search for each individual tags. Check out the official lua ressource for more info and examples on using arrays in lua.
    So i got this now:
    But i get:
    [ERROR] 13:22:23: line :log (arg 2), expected 'string const &' got 'nil'
    Nil indicates that the GET is not working correctly.. if i try and display the response via log it doesnt error but does not give me something back in my window.
    Ok using the debug function i can see that the "response" is empty.. but if i get it via a normal browser, it does have information in it..
    riemers, try to use fibaro:debug instead of fibaro:log
    - Expected 'string const &' got 'nil' => toestel is null, match return nothing...
    replace the line local toestel = response:match(''); with local toestel = response:match('') or '';
    Now i get back: [DEBUG] 13:34:31: Wasautomaat" />
    If i do a second one (so the toestelstatus) that does give me the exact command. Which is "Uit" at the moment.
    Then i should be able to set this value to the virtual device label. The id of this virtual is 173. So i would think it would be something like:
    fibaro:call(173, "setProperty", "ui.Status.value",toestelstatus);
    Where "ui.Status.value" -> Status is the name of the label. But underneath it , i also see a ID for it. Which would sound more logical. But the explanation underneath it does not correctly tell in my eyes.
    So getting closer!
    Update:
    Also tried it like this:
    fibaro:call(thisId, "setProperty", "ui.label_0_0.value",toestelstatus);
    fibaro:call(thisId, "setProperty", "ui.label_1_0.value","Drogen");
    But no values change.
    riemers, you should replace the ID with fibaro:getSelfId()
    try:
    That works, its a shame the api is still in polish and not that great..
    What i dont get is, this is what it should match:
    But i notice that when i save it and go back to the lua script (refresh page) i see this again:
    It adds the behind it, which i did not ask for. Is that normal?
    Whow
    /emoticons/default_icon_eek.gif" alt=":shock:" /> you are right !
    Work with :
    That doesn't change after i save, so thats good. But now it matches the last occurance that ends with />. I suppose you need a $ to say only match till end of the line or something like that.
    [ Added: 2014-03-19, 19:22 ]
    Played around looked on google, i came up with this:
    Dont know what the [[ and ]] does, but it makes it shorter. And instead of (.+) i use (.-) to only match the first occurance it encounters.
    [ Added: 2014-03-19, 21:10 ]
    End result:
    Also checked if it has "remaining time", if so change the icon to be a bit red (like in the screenshot)
    Good news
    in [[ ]] you can pass all you want: ', ", \n, \t etc...
    And there i thought i had it, it seems that if a device is busy, it creates more keypairs.. i read those out. But once its finished it only leaves 2, device name and status. So those other ones i have actually error on me since it cant find them and stops the lua.
    Wow, a dishwasher that outputs xml? Where can I get one of those?
    All (i think) Miele Futura appliances have Wifi. Also there are some Whirlpool-appliances with Wifi.
    I would be surprised if not all manufacturers have something like this in their product line up nowadays.
    The older ones are based on powerlines communications. These are modules that needs to be added and can only be read out by a Miele Gateway device (i think around 600,- euro) each module for miele@home costs money too. I have several devices that can talk like this and show as xml on my gateway. Its costly and it doesn't really add that much sadly..
    But that said, its a nice extra little gadget. The future miele will be with zigbee modules though. Not wifi.
    [ Added: 2014-03-29, 19:59 ]
    This is the end result, sorry about the dutch, thats my language.
    Each device shows if its on or off, what program is running and how long it will take. Some devices can be finished while still on. So i just check if the remaining minutes is 0:00h.
    The cooking plate indicates what level of power is used per hub. So if i set this to level 12 on my cooking plate it actually shows it in my list too.
    Might be a bit overkill but it comes down to the simple rule "just because i could"
    Could you post your virtual device?
    I'm struggling a bit with catching multiple similar xml entries with match. I can catch the first occurrence using your syntax but how do I get multiple ones?
    I only think that if it cannot find a correct entry it will fail and stop 'polling' but so far its working for me and just now and then i still need to tweak it a bit (not all devices get the same output)
    But just do multiple lines for matches (in my case)
    My problem was that the multiple lines are identical (e.g. Server name="" repeated for each server)
    I found a solution.
    See function for getting active plex clients in this thread:
