mvrekum 2
I have a
connected to a RGBW controler. This light sensor has an output of 0-10V. So you should think it would work perfectly with the RGBW controler.Input 1 is set to 0-10V. If the lightsensor is covered, so completely dark, the output is 0 Volt, not connected to anything. However, once connected to the RGBW controler the output will not drop below 1.8 Volt in complete darkness.
Also input 2 is configured as an nrmal dimmer input. On this input I have a
connected. This has a simple relay as output that shorts the RGBW input to ground. When activated the device screen (its a dimmer input) shows a dim level of 68% (should be 100% since the input is shorted to ground)Question: is my RGBW device defective or am i doing something wrong? This way the light sensor is absolutely useless. I can live with the rain sensor however.
Btw, I am using these sensors to control my awning. It automaticly goes down when there is enough sunlight and goes up when sunlight goes away or when it starts raining. I still have to add a windsensor.
39 answers to this question
