How to measure the water temperature how a swimming pool ?
Do someone have experience measuring the water temperature of a swimming pool ? Can be z-wave or IP.
Which device ?
Oregon Scientific seems to have one, but probably not compatible today with HC2
Which device ?
That is not a problem. But you need to be more specific.
1. Is power available where you want the device?
2. How often do you want sample points.
3. Do you need the data to be recognized as a temperature by a HC2?
    Thx for your reply.
    1) power is not an issue, especially if I can capture the water temperature on a tube on the traject to the pump.
    2) Every 15 min, but not so cricital
    3) No, as soon I can read the value from LUA
    Thierry
    any answer?
    any answer?
    Can't you use the
    in combination with a door sensor?
    Why not use the Fibaro flood sensor (FGFS-101) with temperature
    Tcheri,
    You can use UBS or D/W Sensor connected with DS18B20 sensor in waterproof casing.
    • 4 years later...
    There are plenty of devices to measure the water temperature. You can take a look at polygroup store
    • 4 months later...
    I bought the smart pool timer from Thermomart in the following link,
    The product works. It’s good quality. It is easy to download the app and I paired it in 15 minutes.
    This timer saves me $30-$50 a month and also I do everything on my cellphone or by voice (by Amazon Alexa, Google Assistant) from anywhere!
    The Timer can be programmed as scheduled (24 hours 7 days with 8 events) or loop timers if you want to use more event every day. It has a countdown timer too.
    It has a waterproof box and it is suitable for outside. I use the sharing system and now my wife can control the pool pump too.
    Would definitely recommend purchasing.
