franckg16 0
Now I'm trying my first RGB module and I have a problem that I can’t understand:
I want to start a program using the LUA command: fibaro: call ( 112 " StartProgram ", " 1").
When I use this command from a scene. No problem, it starts with the program 1.
But when I use the same command from a virtual device, it starts a program that has nothing to do.
Example:
fibaro : call ( 112 " StartProgram ", " 1") starts the program 9
fibaro : call ( 112 " StartProgram ", " 2") starts the program 7
fibaro : call ( 112 " StartProgram ", " 3") starts the program 8
fibaro : call ( 112 " StartProgram " , "4" ) starts the program 0 ( non-existent program )
fibaro : call ( 112 " StartProgram ", " 5") starts the program 10
etc ...
I tried to # 12 and I see no logic.
I make sure the program Number launched by displaying it in a Label via fibaro : getValue (112, " currentProgramID " ) in the Main Loop
The same tests via a scene work very well, ie they throw out the requested program.
Do you have an idea?
