Hi !
I have a motorised sliding gate which is triggered by a single push button momentary switch. A single push will open the gate until it opens up fully. Another single click will close the gate until it closes fully. If I click the button during the gate is opening or closing, it will stop the gate.
I have installed an 1x3kw Fibaro Switch to get control of it. -> Works fine
Now i have installed an Fibaro Door/Window Sensor inside The Gate to see the Status (opened / closed) -> Works fine
Now the Problem!
When i create a scene for a Timer the pain beginns...
I want a scene which makes ->
every evening at 22:00 and Gate is open then close. If it`s closed do nothing.
So my Scene looks like this
Timer- every Day - at exactly Time - 2200
and
Door Sensor(Gate) = open
then
GateSwitch - turn on
So far so good, but i am not able to open it from that time, because when i switch it manual at anytime from 22:00 hc2 closes it at ones.
What can i do? Thanks for helping and sorry for my English.
[ Added: 2014-03-22, 07:48 ]
no idea?
I think you can not open the gate, because your gateswitch is still on. Turn the gateswitch off after the gate is closed.
Why do you not use the Roller/Shutter switch to control the gate? This one switches off automaticly after fully opening or closing.
    Hi mvrekum,
    That' s Not directly right. It's a config for a momentary Switch!
    But we've got a final workout here ->
    Your code images did not show that. Anyway your problem is solved.
