Php script from virtual device
How to call a php script On My local webserver using a virtul device wo LUA?
I try to add the ip:port together with a GET of the Php script but nothing happens.
Pasting all in one URL in the browser and it works just fine.
Please help!
KristianO, 3 options to do what you need:
1. Use non-lua virtual device
GET /page.php HTTP/1.1
2. Use LUA
3. Use my LUA Toolkit (
) if you need extended possibilities as for example : custom headers and others...
    Thanks alot!
    1. When to add
    - HTTP/1.1
    - HTTP/1.10x0D0x0A0x0D0x0A
    - or just nothing
    add 0x0D0x0A0x0D0x0A if you add custom header or body in your request
    ex:
    Trying to set-up the virtual device but can’t get it to work.
    The same URL in the browser works just fine. "http://10.0.1.10:xxxx/sonos/sonos.php?message=Coming_home&volume=30&force_unmute=1"
    - > It plays the text in the Sonos speaker
    But creating the Virtual device with the same IP and PORT and with following GET request and nothing happens. I tried with/without the response checkbox.
    "GET /sonos/sonos.php?message=Coming_home&volume=30&force_unmute=1 HTTP/1.1"
    Any idea?
    KristianO, for sonos tts you can play directly in lua with my code here:
    or you should use Net.FHttp with LUA to call your php script
    Yes but since i got a hcl i dont have LUA. Thats why i want to Call My php code. Please help
    A.Socha I tried that too, but its not working. I now even deleted the device and re-created it wo success.
    Oh
    As you say in your title: "... From scene" but you can't make http request from a scene. You must make a button in a virtual device and call it from your scene, is this what you do?
    Work for me.
    Sorry, i used the wrong head line. Its a virtual device thats not working.
    IP/Port assigned.
    Using the same in an URL as above it works just fine.
    KristianO, what option you got chosen ? wait for response you got on "on" or on "off"
    I have tried both... None works
    Since i supose that when i push the button, it should call the script?
    tested just and it working here you got my example
    and on target device i get
    ~ $nc -l -p 12345
    Thanks! But what can i do to check why its not working for me? A step by step guidance whould be appriciated.
    Since its still works using the URL from browser
    login on that server and check what you get on port 80
    Can the problem be that i use port 8888 for my webserver?
    No, i think you can use the port you want
    Download Fiddler
    and compose your request with it. Fiddler might help you to debug the response of your server...
    The Call is made and no response is made, can That be The problem? That The vd requeries a response? I just want to Call The request and let The text speak in My sonos.
    that server got linux? if yes change port to some free like 8889 and use command
    nc -l -p 8889
    then when you gonna press button you should saw that get what you was send if that will work check with 8888 maybe you need credentials
    Yes its My local MAMP server running osx.
    The Apache server is set to port 8888.
    How to Apply the credentials?
    I'm sorry but I'm still learning.
    [ Added: 2014-03-21, 09:43 ]
    I have now tried both,
    GET sonos/sonos.php?message=Coming_home&volume=30&force_unmute=1 HTTP/1.1
    Host: 10.0.1.10
    Authorization: Basic (Base64 usr:pwd string)
    0x0D0x0A0x0D0x0A
    and a more "simple" direct TTS
    POST /MediaRenderer/AVTransport/Control HTTP/1.1
    Content-Length: 439
    SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI"
    0,x-rincon-mp3radio://translate.google.com/translate_tts?tl=en&q=There+is+someone+at+the+door,0x0D0x0A0x0D0x0A
    None of them works... Im starting to think that my HCL can't connect in my LAN.
    Any simple test to test that?
