Dear Krystian - I can see that you are responding on the forum. Could you please reply to this one. Fibaro Support is not responding. Also see:
Problem: For some reason the start voltage of the sensor is raised when connected to the Fibaro RGBW module.
When the Windsensor is connected to the Fibaro RGBW Module the wind sensor starts with 0,834v when it is not moving at all. It should be 0v. When I disconect the RGBW module and only have the Power Adapter Attached it gives 0v. So what happens. For some reason the start voltage of the sensor is raised when connected to the Fibaro RGBW module.
