Economyhq 2
Hi Everybody!
1. I´ve got extremly problems with Timers. When i set a Timer which works it is it not possible to do the opposite from that state.
2. And many Timers dont work at all.
Example for 1)
Close a gate every day at 21:00 - if i come home after 21:00 and want to open the the Gate via Remote control (hc2 knows the state because of an door /Window Sensor) it closes at ones. i want that if i tell a timer "at an exact time" the command only at that EXACTLY Time.
Example for 2)
To fill an Variable for "Nighttime" on or off i want to use Sunrise and Sunset. Look at the scene below, this scene only runs when i press "run" by my self. If i take an exactly time it doesn`t work too. (only by Pressing)
any suggestions are very welcome
Greetings from Germany
13 answers to this question
