smoke alarm temp
Guest nohed
you can get access to the temperature of the smoke alarms in a virutuell advice
Guest nohed
    if you get a fire alarm and you are not at home so I have linked the fire alarm to a push message. But if you want to see that it is not a false alarm, I would like to see the temperature of the smoke detekorn in a push message also
