I have a roller/shutter v2 controlling my awning. Everytime when I close the awning by setting the value to 0 the awning closes to 0% and then opens by itself to 1%.
Does anybody know what causes this?
Did you calibrate the device?
    Yes. The device works perfectly, besides that it opens for 1% by itself after it closes.
    mvrekum,
    Please try to modificate parameter 13 to value 0.
    0 - Lamellas return to previously set position only in case of the
    main controller operation
    No, that did not work. I changed parameter 13 to 0, closed the awning and 2 seconds later it opened again to 1%.
    Here is my complete parameter list
    Change 13 to 1 and 14 to 0.
    Works for me.
    Works for me.
    Thanks, I tried that to, but it still opens 1% after closing by itself.
    [ Added: 2014-03-26, 12:53 ]
    Something funny happened today with Razvan's settings still programmed.
    The awning opened today automaticly as it should because there was enough sunlight. Later it closed again when there was not enough sunlight for 15 minutes. It closed to 0%. so far so good.
    Next it started opening and closing from 0 to 1% and for 1 to 0% about ten times by itself. This behaviour stopped because a scene opened the awning again due to the sunlight. Later when it closed, it closed to 0% and stayed there. No more opening to 1%.
    While I am writing this the awning has opened again. Now i am waiting for it to close again. I hope it again stays closed at 0%.
    I keep you informed
    [ Added: 2014-03-26, 14:15 ]
    The awning closed for the last time today (the sun is on the other side of the house now) to 0% and it stayed at 0%. I still do not know the main cause of it opening and closing, but it works for now.
    Thanks to all for your input.
