rajnish 0
I am facing very serious problem. My scenes were running despite the IF condition being false. For example I created a variable called 'MovieStart' with initial value as 1 and used it in a Movie scene with IF condition as MovieStart ==0. Then too the movie scene triggered. This was happening for all scenes. I then saw its LUA code and strangely the LUA code was showing another variable being added by the system in the IF condition with OR parameter, which was making the IF condition always TRUE irrespective of the variable value. If I edit the LUA code and remove this system generated parameter then my scenes ran perfectly. However with converting the graphic mode into LUA, one looses the convenience of graphic mode as once switched to LUA code fro editing the code I cannot switch back to graphic code.
I am attaching the to screen shots of the same scene... one in graphic mode and other one in LUA mode with error being highlighted.
Need urgent resolution
8 answers to this question
