Beta version is designed for user testing and soon will be released as official.
WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
Mobile apps fully working with this version:
- iPhone app - version 2.1.1 (available on the App Store),
- Android phones app - version 1.3 (available on the Google Play),
- iPad app - version 1.2 (available on the App Store).
3.591
- Minor changes and improvements.
Installed remotely, no problems for me but what improvements can we expect with this release?
regards
Probably minor fixes for the motion sensor and gateway connection...
A stepping stone...
Installed, don't see any change
Jacques
In order to update to 3.901 alpha Home Center 2 must be first updated to version 3.591 beta
Bad start : on my main HC2 : "upgrade error 6"
On the slave HC2 : ok
I got no error
Should be in section for 3.901 alpha version, please disregards - A lot of errors and bugs in the 3.901 alpha version!!! messed up virtual devices, gone back ups, forbidden access to newly added Multi Media device.
Be aware before installing, no way back as back ups are gone.
Please see bugzilla for threads.
Second try, upgrade ok
How do I update to any version?
I don't have an upgrade button...is there firmware download link?
On Configuration Tab there will be a bottom section with an Upgrade button whenever there is a new version available. For the Alpha in another thread you need to send MAC and Serial# and you will then receive an individual upgrade link for your system.
@Fibaro
Any news about the HCL upgrade?
Need a stabile version for the HTTP connections
backups are OK, you have to do full recovery to get back latest stable version.
If i upgrade to this beta, can i also upgrade to the next stable?
Or do i need to downgrade (recovery) to 590 in order to be able to upgrade to the next stable when it's released?
Thanks,
Peter
Guest dsilletti
Thanks,
Peter
Hi Peter, you can always upgrade from HC2 betas to the next stable,
be careful if you have a lot of devices and hard config, betas sometimes are unstable and disruptive.
In case of big problem, to downgrade, you have to restore from 0 your HC2 and upgrade step-by-step to 590 then reload your last 590 backup.
regards
Domenico
I do the Update 3.591 end now i do NOT can see my webcam,,foscam fi8918w,, in remotte acces. locali access i see the webcam end i can move the cam. when in do the remote access with my work laptop or my iphone in another network i do Not can see my webcam. Any idea ?????? Can i do the downgreate to 3.590???????
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> You have to replace the model "Foscam" with another model, such as "Apexis" and leave the same parameters that were in the old configuration. So it works again.
Sorry for my bad English
My motion sensors from Fibaro false trigger at least once a day and stay breached until movement ist detected. Obviously the Z-Wave Network is on overload which will be fixed in V4.x. Since this update is probably MONTHS away I wonder if anyone else is having this issue.
What do you do?
I hate false alarms at night!
5 days uptime with no serious problems think I have beaten a personal best
Guest shapa
I've got 1+ month stable system with nearly 150 physical devices.
Keep fingers crossed.
