mvrekum 2
I need a little scripting help. I have a scene that has to run for a variable number of minutes.
I have the variables "StartTime", "RunTime" and "EndTime"
StartTime is the current time
RunTime is a global variable with the amount of minutes given by another scene.
EndTime is StartTime + RunTime
I compare the current time with EndTime to stop the script.
The problems start when you go over the hour, like StartTime = "1155" and RunTime = "10" then the EndTime would be "1165" it should be "1205"
The same happens at midnight with the hours 23xx to 00xx.
Can anyone help with a simple solution?
4 answers to this question
