Better understating for scenes
Hello
I made a couple of scenes to use with XBMC at night time only but they run automatically when it's night time without even running XBMC , i'm working to resolve this but i need to ask a couple of questions to have better understanding for scenes .
- What are the check boxes for " Active scene " and " Start when HC2 starts "
- if i don't want to add a trigger for a scene ( i'll manually run it ) what should i do ? do i have to add a dummy one time trigger ?
Rami
I got the info that active scene is just an on/off setting mean while the start when hc2 starts is related to the timer setting is scene. Both should be checked and is a misspell, valid for both hc2/hcl.
Set a time in the past with a one time trigger.
