Working scene panel - Z-Wave.Me Controller Double BJ 2000
Guest shapa
Just verified - Z-Wave.Me Wall Controller Double BJ 2000 works fine (scenes buttons detected by HC2 v3.x)
9 answers to this question
Will it work with HCL ?
Guest shapa
    Probably not, as HCL doesn't support LUA and the only way to use scene buttons today is via lua code...
    shapa is correct. Currently it will not work in HC Lite. There is no way to trigger a scene by "scene activation", even in case of Fibaro devices.
    But it seems like Fibaro plans to release scene activation funtionality in scene graphical blocks. Please see:
    I also wait for that. It is very important to have in HC Lite since there is no LUA. I hope it will happen soon...
    How did you get the scenes working? What parameters did you use?
    Guest shapa
    Set parameters 11,12,1314 to 4
    It is mentioned in the included manual.
    I did. But how do I select the scene I want to run?
    I cannot select a scene ID in the group-id.
    I set params 1 and 2 = 0 to make the buttons act individually, not as pairs.
    You can make the code respond to different button pushes ie click, double click, hold etc. First digit is button number 1-4, second digit is the action to monitor.
    The numbers to use are in the confusing manual!
    %% properties
    70 sceneActivation
    %% globals
    -- 70 is ID of wall switch
    local button = tonumber(fibaro:getValue(70, "sceneActivation"))
    if button == 31 -- Wall switch button 3 single click (1)
    then
    fibaro:call(54, "turnOn"); --Extractor fan
    if button == 32 --Wall switch button 3 double click (2)
    then
    fibaro:call(54, "turnOff");
    Thanx, you really got me started!
    I made a virtual device with one label and some main loop code (one global variable is needed) . as far as I can tell this works like a charm!
    For those who want to use (a bit) of my code:
    This example is using button 1 and 3 to turn on/off a lamp (ID=10), button 2 and 4 to press a button on an another virtual device (ID-128). Under configuration you change the settings depending your own HC2 setup.
    Guest Tobiasfranzen
    I´ve just got my z-wave.me double wall controller.
    Can someone tell me step by step how to config it?
    parameters?
    number - data type - desired value ?
    I want to Control my fibaro roller shutter 2 up/down
    I have 2, therefore double wall controller
