Some time ago I built in multiple Fibaro roller shutters (FGR-221). Back then I used a different controller and I had to choose whether 100% was completely closed or open. Now I switched to a Home center I know that I made the wrong decision. When I open the roller shutter in the HCL it is actually closes and vice versa.
But in order to change the wiring on the components I have to break the wall open
/emoticons/default_icon_sad.gif" alt=":-(" /> .
Is it possible to switch the open/close state without actually touching the modules? For example:
- Change a parameter in the software (module or HCL)
- Switch the manual control buttons (not preferred, but possible)
Why you don't change the cables in main switchboard?
    I built them in the wall with wallplaster over it. So I have to break the wall open in order to get to the main switchboard of the module...
    Hi Savage, there isn't such a parameter. I suggest to look into your shutter enclosure, sometimes there is enough cable to cut it en to switch up/down wires.
